EBL 99 battery cut off
Aberdeenshire
B524
2nd base
Does the battery off switch on the EBL 99 activate the boiler dump?
I'm wondering what the easiest way is to have the batteries off charge in the van but still have power to 240v system.
Take out the 20A fuse front left of the EBL . Next to the one for the fridge. Labelled "internes landemodul". That way everything else will work.
As paddymcc says, taking out the 'Internes Lademodul' fuse cuts off the mains charger from the leisure battery. But it leaves the trickle-charge to the starter battery still working. That may be exactly what you want. If it isn't, then pulling out the mains input plug where it enters the EBL will cut both off.
