EBL 220-2 Schaudt
Cambridgeshire
Burstner 747 - 2
Hi ya funsters
By the power of Motorhome Fun
I would like to ask if anyone knows if the selector switch for the number of auxiliary charging units. The very small red switch in the picture. Is set correctly, I’ve only got the power cable plugged in as normal. Should it be set to position 1 is that what it means been reading to long and getting confused.
It translates to 'Number of additional chargers'. The EBL has an EHU charger built into it, but you can plug in an additional EHU charger for more power. I assume that refers to only EHU chargers, but you'd need to check the manual to see if it refers to any other types (solar, b2b).
There only the manufacturer charger no solar? So I guess the setting should be on 1 as there is no auxiliary chargers
Yes I would think so (as 'oder' is 'or) if you're sure there is no external charger plugged in (is that what it's on now)
It’s hard to see but the picture looks like it’s on setting 2, I’m kind of thinking it should be set to position 1 as the only charger the Motorhome has as far as I’m aware is the Electroblock
When it's set to '2' it cuts out the solar leisure battery input that goes into the 3-way connector Block 5 just to the left of it, but only when the mains charger is powered. I think it's intended to avoid overloading the internal wiring of the EBL. An internal mains charger, plus two additional mains chargers through the front panel connectors, must max it out, so no capacity for any solar.
When there's no hookup, the solar operates as normal. However since you have nothing plugged into that 3-way connector, that switch won't have any effect, so it can be in either position.
Thank you, then if it’s not having any impact best I leave it alone.
Had the Motorhome since new and I wasn’t sure if I changed it while looking for the battery selector gel or lead acid 👍
