2001 Pilote G270 A Class on a 2.8Hdi Peugeot Boxer.
Need to replace the cam belt, also the radiator has a small leak so decided to both at the same time. Looking around I could see the front fibreglass area is in sections. A day's work and managed to remove the central strip carrying the logo, the lower skirt and the heavier section carrying the headlights. It soon became clear that many of the fasteners were heavily corroded meaning carefully use of a small battery powered angle grinder. Finally removed the top cross beam holding the radiator that is an original Boxer part apparently cut down by Pilote. I will replace fasteners with stainless on reassembly, perhaps going up a diameter.
So yes, who said no access on A Class vans?
