Does that mean that any appliance with a metal casing and an earth could be dangerous unless the inverter is earthed?Anything that relies on a safety earth (in other words anything that isn't double insulated) will lose that protection when connected to an inverter. Earthing one side of the output of the inverter creates a neutral and restores protection.
Not quite, the appliance will be protected by a rcd, so it needs a inverter that’s rcd compatible. Professional inverters are compatible with rcd.I have heard that it is not safe to run earthed appliances from an inverter, is that correct?
Not necessarily. Dangerous in terms of you touching something and receiving a shock - unlikely. But a fault in the appliance might not blow a fuse or trip the RCD until next used on EHU.Does that mean that any appliance with a metal casing and an earth could be dangerous unless the inverter is earthed?
I can agree with this if you assume the inverter earthing point has no reference to its output; i.e. the output winding is still isolated.The earth in of the sockets should be connected to an earting point on the inverter which in turn should be connected to the EHU earth connection.
Thank you. It will be isolated from the rest of the 230v system. I have details of the spade connector to be moved to bond earth to neutral. I will just connect an RCD and MCBs.My opinion, for a 500va inverter keep it simple and isolated to the rest of electrics, its double isolated and a rcd will not help you without a N PE bonding. If your inverter manual documents snd provides a bonding option, then its possible to be done inside on the pcb spade connector.
If not, forget about the bonding, and use it with suitable over current protection, fuses/ breakers.
Thank you. I wasn't sure either, which is why I asked the question.I don't understand why you would want to introduce an 'earth' when an inverter effectively provides an isolated output. In other words, the output has no reference to true earth and therefore can not provide a shock from extraneous metalwork in a fault condition to true earth.
Over current protection should of course still be provided.
Thank you. The system will be totally independent of the EHU circuits.The earth in of the sockets should be connected to an earting point on the inverter which in turn should be connected to the EHU earth connection.
Thank you. From what I've read in this and other posts, I will not be connecting the earth point to anything.I can agree with this if you assume the inverter earthing point has no reference to its output; i.e. the output winding is still isolated.
If you strap one side of the output connection to the inverter earth point and/or the EHU earth connection, you have introduced an unnecessary reference to an artificial 'earth' which increases any likely shock hazard.
The earth in of the sockets should be connected to an earthing point on the inverter which in turn should be connected to the EHU earth connection.
It does if it’s bonded to neutral, it goes back to source as it suppose to. Adding a third conductor, PE, provides a safe path back to source for the fault current, ( floating earth).If you are not using EHU (which is most likely if you are using an inverter) then the earth will not be going anywhere anyway???
If you have ehu why would you use an inverter?The earth in of the sockets should be connected to an earting point on the inverter which in turn should be connected to the EHU earth connection.
If you have something like a Victron Multiplus II and you are on an EHU that has limited capacity - say 10amp or 6amp, the inverter can cut in to share the load if you need more capacity.If you have ehu why would you use an inverter?
