Yes, it´s a straight swap ( get the same spec though, heated mirror etc) , easy enough to do and you won´t see a damn thing ......... I tried long to short after a mirror clash, swapped back to long straight away, couldn´t get a medium to try so don´t know the answer to that, but long to short on a 2.35m wide MH with standard Fiat cab is a no from me.Does anyone know if it's possible to replace a long arm mirror for a shot arm one on a Fiat Ducato and is it a straight swop and can you still see behind ok ?
Thanks for the reply thats just the advice I need.Yes, it´s a straight swap ( get the same spec though, heated mirror etc) , easy enough to do and you won´t see a damn thing ......... I tried long to short after a mirror clash, swapped back to long straight away, couldn´t get a medium to try so don´t know the answer to that, but long to short on a 2.35m wide MH with standard Fiat cab is a no from me.
