Ducato rear springs (1 Viewer)
Ian Kelly
9
11
Pershore
Ace Airstream2008
Mot test has identified a cracked rear leaf spring, would this be a good opportunity to upgrade to double leaf springs to improve ride and comfort.
Members views would be welcome.
Mikey RV
4,895
24,167
Devon
Burstner Elegance I821G
Since 1977
I would say yes. If you gonna replace anyway and can afford the upgrade then go for it. (y)
TheBig1
17,606
43,108
There is a place in the midlands that makes uprated leaf springs. A very good idea if you are changing one anyway. Motorhomes are built on van chassis, but unlike a delivery van they are constantly loaded.. uprated springs will raise the rear of the van slightly and allow better suspension travel before bottoming out on the bump stops
Jul 13, 2008
3,737
3,819
Low profile
A double spring might make the ride too harsh and the dampers might not cope either. If it's had one from new I would stick with that.
Aug 19, 2013
2,950
4,274
Wells, Somerset
Elddis 115
since 2004
I was told that there are no shockers as such on the X250/X290 standard chassis but instead use rubber blocks, and that as was said earlier because motorhomes are always loaded, they are often sitting close or on to these blocks. Is that so?
Jul 13, 2008
3,737
3,819
Low profile
No.
Apr 22, 2018
6,817
12,551
Herts.
Adria Coral lowline
There are dampers, like most vehicles and then there are spring assisters, which are also bump stops.
I
Ian Kelly
9
11
Pershore
Ace Airstream2008
Have decided on double springs on the advice of the Spring manufacturer, ( Jones Springs, Walsall) who manufacture and supply at a very good price.Will report on ride and handling when fitting is complete. Pair of Rear Springs ÂŁ24o ex works can't be bad!
TheBig1
17,606
43,108
that's the firm, just couldn't recall the name
tonka
10,827
21,515
Cannock, Staffs
A class Burstner 800
Since 2000
You guys beat me to it..
Was going to say Jones springs in Darlaston (y) Good old Black country firm.. :D
https://www.jones-springs.co.uk/
Aug 19, 2013
2,950
4,274
Wells, Somerset
Elddis 115
since 2004
That sounds amazingly cheap. It'd be great if you could report your findings.
TheBig1
17,606
43,108
I used to know a guy that was forever playing with the springs he sold.....a complete windup merchant
Sep 28, 2015
2,010
2,600
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
The ride on pre Defender (coil spring) Landrovers was improved in the same way. My MK111 short wheel base was solid on its original leafs, designed to work with a very heavy load only.
Sep 12, 2011
134
85
london
coachbuilt
Second Jones springs very good easy to fit if you have the tools. Certainly improves the handling along with air bags.
Dec 31, 2010
2,632
5,815
Sunny South Shields
Frankia Platin i7900
Since 2010
If anybody is after new leaf springs or new front struts you should try SAP
Ask Mick as he changes many new vans like mine to full air also ambulances so the parts are redundant I am sure he would do a cracking deal on some. đź‘Ť
