That makes sense. It must have two power feeds. A constant live and a switched live. The default is the switched live but it will allow 20mins on the constant live. If you make both inputs constant live it will stay on indefinitely.I belive you have to change the wires over at the back of the radio its the red and the yellow one's.
But you will need to look up which way round for what.
The old ways are sometimes the bestOn our old Burstener we had a seperate switch on the dash board that worked off the leisure battery,so when the ignition was off you could switch on and listen to the radio as long as you wanted to.
Me too!On our old Burstener we had a seperate switch on the dash board that worked off the leisure battery,so when the ignition was off you could switch on and listen to the radio as long as you wanted to.
Yes I saw that. I’ve already got the MultiEcuScan and am operating on Apple so that option isnt open to me. Was looking for cheap easy fix or seeing if Fiat have updated software since 2015.The radio is controlled by the body computer on newer vans. They are supplied with default switch off times of 0 and 20 minutes from the factory, but the body computer can be reprogrammed to 60 or 120 minutes switch off delay.
I posted a thread explaining how to do it with AlfaOBD diagnostic software a while back.
The software allows for two radio off-delay settings. I'm afraid to change them the body computer needs to be reprogrammed, and the new delay times will then be available on the radio settings screen.Yes I saw that. I’ve already got the MultiEcuScan and am operating on Apple so that option isnt open to me. Was looking for cheap easy fix or seeing if Fiat have updated software since 2015.
