OP said it won't start when warm .....never said won't crank over.Start by tightening all battery terminals and starter motor contacts and check your earth straps. Heat on an already loose connection can make it have even less contact?
OP said it won't start when warm .....never said won't crank over. Obviously a fuel problem
Thanks both. No it turns over fine, almost starts, then dies.OP said it won't start when warm .....never said won't crank over. Obviously a fuel problem
I'm only suggesting something that is easy to try first . I had a contact that expanded when hot on an old starter - replaced cable and solved issue.OP said it won't start when warm .....never said won't crank over.
