Without stating the obvious Doug, but have you tried a search?can't seem to easily re-trace the query regarding fiat carthago cab heating fix. is there an easy way without scrolling through miles of threads?
I did read a post on FUN, where another Ducato owner complained about a lack of heat to the drivers side footwell. Apparently, the fitter removed a static footrest, which was partially blocking the air flow from the heater vent.yes it was the carthago 143. seems that its a common problem to ducato converted from left hand drive. drivers side receives negligible heat whatever the settings. lots of replies to the thread and i wondered if anyone else had a simpler remedy. will try the search.
