PaulandChrissy
Ducato Dashboard Nik Nak Table V1
No permission to download
Harpenden
Auto Trail Comanche
PaulandChrissy submitted a new resource:
Ducato Dashboard Nik Nak Table - Dashboard Table Kit, 3D CAD files
Print 2 of each item. Assemble the 2 shelf trims and the 2 joining clips and glue together with superglue. Once dry, lay the assembled frame upright over a sheet of 3mm ally and mark out the sheet size using the frame as a template. Cut the ally sheet and bond to the underside of the frame with a hot glue gun. You can prepare the ally sheet with any surface finish you desire. I used those grippy rubber sheets cut to size. Lay the 2 Shelf Bracket Rails onto the grooves on the top of the dash...
Read more about this resource...
