Having the van's first service tomorrow at Thomsetts in Stockbury, Kent. Heard good things about them on here and hoping all will go well (the old/young girl has only done 7.5k miles since we picked her up in July '22). However, initially I decided to have them replace the oil, oil filter, brake fluid and fuel filter only, thinking I would do the air and cabin filter (how hard could that be?!). I've seen a few YouTube clips of both filters being changed and it seemed fairly easy (although I also believe Wolverines would make good house pets!) so I purchased both filters for what seemed like a reasonable £28 and got stuck in to changing the air filter first. When I say stuck in I mean I opened the bonnet, looked in and went 'Ah!'. Things have obviously changed a little under the bonnet of newer Ducatos. I was expecting to see jubilee clips but was confronted by these:
They look like they should be prised apart with a screwdriver but my concern was whether a specific tool would be needed to fit them back again. I didn't want to risk removing the pipework from the filter housing unless I could be certain of refitting them again. Does anyone know what these type of clips are called and how they are removed and re-fitted? Putting aside that disappointment I moved onto the cabin filter. Once again, things have moved on a little from previous Ducatos. Whilst I was able to remove the three screws (I hope there weren't more hidden) that hold the lower centre consol in position, I couldn't seem to remove the console itself. Another concern was the usb port in the middle of the console (it wasn't fitted in the YouTube clip I saw). Does anyone know if this needs to be prised put of position and the connector removed first or should the whole lower console come away with this in place?:
Scuppered then on both fronts and now Thomsetts will be doing the full service. Thoughts on above priblems most welcome.
