Ducato 244 powerwindows / central locking issue
slider
ducato
Hi thanks for your time reading my post I recently bought a ducato 244 (2005) with not working electric windows on both sides, i did today replaced the window regulator and tested with direct 12v works! but using the switch is a no go, the green/white wire on the switch has 12v, ...anyone has an idea?
second question, try to replace the interieur fan but cant really figure out how to remove it (anyone has a video?)
last question, central locking is ALSO not working anyone knows if there is a relay? (fuses are all godd)...
It’s all a process of elimination and can be long and drawn out
1.
Try removing the window switch from its housing and checking for power supply and also for earth.
2.
Put separate power supply to window switch see if it works.
3. But 1. really
Have you checked all the fuses 😉
Hi yes i can only one labeled fuse on my ducato 244 for the windows (and i can't find the central locking one) using direct power to the window regulator motor works...meaning then it goes up and down..
The reason I ask to connect to the window switch rather than direct to the motor is to establish if the circuit from the switch to the motor is good.
