Drop down tv
charl
Llantwit Fardre, Wales
Hi top
since 2008
Can any one tell me how me how to switch on the lights that are on eithe side of the drop down tv, :Confused: I don't really need them I just like to know how things work
hi charl and welcome....
i think we may need a bit more info.
are the lights original to the motorhome or an extra fitment or part of a fancy tv casing. ?
recessed downlights or swivel type eyeball lights. ?
would it be possible to take and download a photo.
S
sinbad1
not sure which lights you are talking about, maybe the dropdown tv is an add on
Link Removed
if its these lghts then they are 240v and will only work when on EHT switch is at the side dimmer type
billy
Bolton
Autotrail
since 2009
Hi Charl
I have a miami i cant get mine working either:cry::cry:
billy
Bolton
Autotrail
since 2009
Hi All
The lights in question are part of the drop down tv console in the cab
I think they are supposed to come on when you open the cab doors but they dont
i have have fiddled with the switch and checked the bulbs they are ok
S
sinbad1
Hi All
may be wrong ;but isn't the dropdown tv powered from where the psu unit is and for it to work two switches need to be on. maybe then the two lights will work.
ignor my earlier post
are these the two lghts you refer to Link Removed
regards
C
charl
Hi top
since 2008
hi Sinbad yes this is the tv console, even with the switches turned on these lights don't work but the tv works fine
S
sinbad1
Perhaps it would be a good idea to give seargent a call there is a phone number on their site , sure thier technical staff will be able to help you
Link Removed
ps
be interesting to find out how they work :BigGrin:
DJP
Somewhere in Europe
The light will not work as they are not wired to any live supply. It is the same on ALL Autotrails with that stlye of drop down TV with lights.:Sad:
billy
Bolton
Autotrail
since 2009
Not quiet true if you take the right hand light lens cover off and look just infront of the bulb you will see a little switch turn this on.
It worked on my Autotrail miami but does not work on all Autotrails.
richard fuller
Norfolk
autotrail
two
lights on tv monitor
I have a 2009 tracker and when I purchased it the dealer told me they were not wired to work ( so why fit them autotrail) it must be easy to install the wiring to the lights during manufacture. To make things worse the cab lights canot be switched on only by opening the door,yet another thing they cant get sorted:shout:.come on autotrail listen to your customers and get things right.
Somerset
Since 1996
My lights work NOW since my recent service :Smile:
they never used to but I didn't really mind but did notice they were working when I opened the door after the service.
mi mi
Devon
since 2009
We had the same problem when had a new unit fitted.. need to take off right hand light cover and there is a switch behind which maybe in the off position.
Hope this solves your problem.
pvw10
Gloucester
Coach built
since 2011 after tugging.
My Miami drop down tv has a slider switch on the side, on/off/doors so is easy.
pvw10
Gloucester
Coach built
Total cobblers to make a sweeping statement, mine work perfectly
