- May 14, 2018
- 376
- 522
- Autograph 794-T
- Caravan owner moved on to Motorhome
Perhaps a 'delicate' question. Can you get up to much 'hanky panky'
on those drop down beds, are they up to the job... asking for a friend.
Not sure they're meant to support a 'threesome'!Wish I could answer that, but if we are ever both in the drop down bed, it’s because we have a guest![]()
Twice a year ! That many?!I know an old guy and his missus with a German a class with a drop down bed who bonk on birthdays with no ill effect and the bed is ok too they say.
Not much room for two let alone 3 lolNot sure they're meant to support a 'threesome'!![]()
Ours in Benimar 486 is big, very spacious and comfortableNot much room for two let alone 3 lol
Course they can! The third person just kneels under the bed t provide support for the main structure ...Not sure they're meant to support a 'threesome'!![]()
Ditto from me and her. A tip though make sure the bolts that hold the bed to the guide channel are tight as ours had a habit of coming undone and the whole think turned into a swing !!Lol you lot what u like
I’ll give you sensible answer
Drop down beds have a maximum weight so as long as you don’t have a party on it u should be ok.
My 486 Benimar come down and will stop at any height, however it do come right down on to settees so it’s not going anywhere when you party![]()
Counting the days thenI know an old guy and his missus with a German a class with a drop down bed who bonk on birthdays with no ill effect and the bed is ok too they say.
Is there not the matter of static versus dynamic load to consider?Drop down beds have a maximum weight so as long as you don’t have a party on it u should be ok.
Best start boosting vitamin and energy pillsDitto from me and her. A tip though make sure the bolts that hold the bed to the guide channel are tight as ours had a habit of coming undone and the whole think turned into a swing !!![]()
Counting the days then99 sleeps to Chr! $£mas.
Perhaps a 'delicate' question. Can you get up to much 'hanky panky'on those drop down beds, are they up to the job... asking for a friend.
We do that on my birthday February 29th ?I know an old guy and his missus with a German a class with a drop down bed who bonk on birthdays with no ill effect and the bed is ok too they say.
Your experience means that the question, 'Do you fancy a screw?' may not lead to the outcome you envisage ... But it may still involve lying on your back and stretching to ring matters to a conclusion, if not a climax ...Ditto from me and her. A tip though make sure the bolts that hold the bed to the guide channel are tight as ours had a habit of coming undone and the whole think turned into a swing !!![]()
I've reached the age where it's a relief rather than a disappointment to get a refusal ...My mate says yes, but sadly not very often![]()
But only on alternate Leap Years? Because, as national football teams prove repeatedly at the World Cup, 4 years preparation is never enough for a winning performance, even if you can bring on 3 subs with 5 minutes to go ...We do that on my birthday February 29th ?
Phil
The fuse will get blown more often?Blimey 2 threads about drop down beds. Easy to confuse which is which.
Blowing a fuse ... occasional nookie ... what's the correlation ... ??
SWMBO has often said I have a screw loose or was it a loose screw!! Oohh I remember now "Screw You"Your experience means that the question, 'Do you fancy a screw?' may not lead to the outcome you envisage ... But it may still involve lying on your back and stretching to ring matters to a conclusion, if not a climax ...![]()
Steve
