What pressure should it run at I see the gauge red line at about 20 psi and the actual readings are lower. I'm assuming the red line is set by installers but don't know.
I could not see any instructions on line so any advice is appreciated
If you can access the rear of the meter check for two pipes. I suspect @tacr2man is correct and each needle relates to a different side of the van.Are you able to move the red needle , as it might well be that red is one side and black the other ? @GeoffChausson
Don’t know about driverite bu we have VB on rear and they advise min of 100psi.
This should be of help to you @GeoffChaussonNot tried inflating yet but that makes sense as manual system. Just need to find out what pressure should be used
Yes just checked two pipes, I thought the red may have been a max pressure setting
Sorry my mistake should have been 1 bar at this age the old memory ain’t so good could have ruptured all the air pipes had you used my advice.I have VB Comfort Semi Air on the rear of our ALKO chassis and the maximum pressure is 3.5bar (50psi) whilst crawling along or around 2bar (30psi) in normal use.
