I’ve already tried posting this on the general site and only had one response, which sadly wasn’t much help, so though I’d try the Bailey site to see if anyone else has the same issue.
If I open the garage locker doors after rain, or I’ve washed the MH, water drips out from the seals and some gets inside the garage. The seals have small holes every few inches and looks like the water is getting inside. Blocking the holes may work, but I wondered if anyone has had this problem and found a solution?
I thought about fixing some sort of gutter above the doors, but when they are open there is only around 10mm clearance between door and body, and I can’t find anything that thin.
Can’t see any identification on the doors, but photos attached.
PS The first photo shows my solution to the locker door not latching up: use a heat gun to soften the catch, twist it slightly and hold it at that angle until it hardens. I know there have been various suggestions re this, but thought I’d add my version
