Afternoon.. Just wanted to double check my planned install/changes before I purchase a load of expensive kit.
I plan to fit a Victron 50a B2b (Victron Energy Orion XS 12/12 50A) along with a Victron main charger (Blue smart IP22 12v 30a) and fit this in/around my current setup (picture attached). I'll also be installing a 300ah'ish Lithium battery.
To fit the b2b I plan to follow the instructions here (https://support.roamer.com/en/articles/1996290) as this is a near identical EBL unit and seems to make sense.
To fit the main charger I plan to leave the current hook up connected to the EBL but pull the fuse out so it can't charge the leisure battery. I then will attached the new charger to this side of the consumer unit and then to the leisure battery. I wanted to keep the current EBL connected so it can still trickle charge the starter battery as this is a feature that's useful.
Does this sound reasonable?
Any help/advice appreciated.
