I bolted brackets to the chassis rail by inserting rivnut into the chassis rail and bolted length of 1/4" x 1/4" x 1" aluminum angle to the lower vertical section of the sill. The jacking point is clear, although in the photo it looks obstructed.I 've looked at Vanpimps fox runners but they dont do a short version only full length for swb and mwb vans.
Two on Tour how did you fix your brackets. Vanpimps use the jacking points, where do you then jack van up?
Two on Tour the words made sense of the picture previously posted (i searched your old posts). Thanks again.
The only problem i can see is the depth of the fairing bellow the door, requiring a short platform.View attachment 556394
Yes i need to bite the bullet buy the rails then have a play, the weathers perfect for grovelling under the van (Drizzle).You could shape the rear end of the step to follow the line of the molding or have longer brackets to mount the step lower.
I'd seal that ply with epoxy resin. In that location it'll delaminate before your very eyes.
Just seen this vid
From this company
Can anyone understand enough to work outAltago
Altago est le réseau de pose d’équipements pour camping-car, caravane et fourgon sur toute la France et en Espagnewww.altago.fr
how much ?
Are they available over here ?
Or any other uk offerings.
Two on Tour due to your inspiration and the rediculous price of the ebay item i took a punt on the vanpimps fox runners. The black plastic trims come off easily, not glued on as i feared. One side of the swb version is enough to make both sides. I used the vanpimps brackets and a few bits and pieces to level up due to the depth of the fairing. At the rear i used the supplied bracket and a modified MZ exhaust bracket to mount to an existing point on the van. The bracket perfectly reaches a frame member. A quick drill and rivnut and it looks as if it was intended to be there.the rear plastic bit needs a slight modificstion to avoid the exhaust..
Ps needs a clean.
Most important bit SWMBO is happy.
Thanks for advice, just had a little play getting in and out and so far happy. Have opportunity to extend out a little bit so may have a play tomorrow.Nice job.
We find it easier to come out of the cab backwards with our sides steps, as coming out forwards with the narrowness of the step seems to launch you headlong.
Any photos of the fixing brackets?Two on Tour due to your inspiration and the rediculous price of the ebay item i took a punt on the vanpimps fox runners. The black plastic trims come off easily, not glued on as i feared. One side of the swb version is enough to make both sides. I used the vanpimps brackets and a few bits and pieces to level up due to the depth of the fairing. At the rear i used the supplied bracket and a modified MZ exhaust bracket to mount to an existing point on the van. The bracket perfectly reaches a frame member. A quick drill and rivnut and it looks as if it was intended to be there.the rear plastic bit needs a slight modificstion to avoid the exhaust..
Ps needs a clean.
