- Jan 23, 2023
- 273
- 272
- Burstner Travel Van
- Newbie - bought first MH 11/03/2023
I’ve considered doing just that but on my van the two parts are offset when they meet leaving very little to drill throughDrill two holes, one down both bits of plastic in the center. Make a double hook from some thick wire. Job done.
Here's what mi e look like on the van .. you will only need the oneAfter recovering from ear bashing from her indoors for glue on her kitchen worktops and one bent steak knife I made these magnetic catches.
I do not understand why MH builders fit these plastic clips relying on friction.The 15 year old catches on my Burstner seem to be overcome by not very strong gusts of wind.
Questions:
Would fitting identical but new & unworn catches give a noticeably better hold.
Has anyone replaced this type of catch with something better.
View attachment 781332 View attachment 781333 View attachment 781334
Good idea - I’m thinking one hole through all pieces and insert a small golf TeeDrill two holes, one down both bits of plastic in the center. Make a double hook from some thick wire. Job done.
That what we have on oursI do not understand why MH builders fit these plastic clips relying on friction.
Truck rear doors are held open by metal 'T' shaped arms which drop down into slots on the truck walls. They use mechanics not friction
Look at them next time.
I am not sure if one can buy them to fit existing hole centres and internal reinforcement may be needed.
