- Jul 6, 2009
- 2,316
- 2,969
Evening all, I have this three burner hob fitted in our 2019 Burnster which we have owned from new. The burner developed a bad leak as I have previously posted. The problem now is it would seem that this particular hob is no longer produced. There is a problem in it would appear that the burners should have a small projection of the tube projecting out on the side that goes to the inlet manifold. This it seems is to locate the sealing washer to ensure it is a good fit to the inlet pipe. When this hob was installed there appears to be no supporting clamp on the pipe run to supply the gas. This can vibrate but not apparent as it is under the unit behind a draw. Bit sad for a three year old van. The burners are available but not the manifold pipe and gaskets. Needless to say any re assembly will be done by a gas safe engineer. Completely mystified as to why these short bits of pipe were loose when removed. One end is smooth as if cut, the other end is rough as is the end of the pipe in the burner. If you watch the clip the spray blows away when gas is turned on.
Any ideas please
Any ideas please
