We have a Dometic RMS8401 fridge, 4 years old, never given a problem. Last used about a month ago. Tried to turn it on a few days ago and the control panel on the front is dead, the fridge just won't turn on. Fridge interior light not coming on.
The permanent feed at the back of the fridge from the leisure battery is fine, the feed from the alternator is fine when the engine is running. The only unusual event I can think of is that we had 3 successive days of hard frost last week.
I've downloaded the Dometic service manual which doesn't quite match our fridge, it shows a 1A fuse on the PCB behind the control panel but there is no fuse on ours. The only connections to the control panel are a ribbon cable and a thin twin-wire lead. The control panel is the manual-switching automatic ignition one with the squidgy buttons.
I've tried disconnecting the permanent feed from the leisure battery and leaving it disconnected for half an hour in the hopes it may reset the control panel but to no avail.
I can order a new control panel part #2890638-02 and the panel appears easy to swap out but I'm just wondering of there is any other troubleshooting I can do first. And if anyone has actually replaced the control panel did they have any issues I should be aware of?
Thanks in advance.
Thanks in advance.
