Dometic RMS fridge cooling issues (1 Viewer)
Jun 28, 2024
91
19
Leicestershire
Autotrail Apache 634
Since 1998
So just bought a 2011 Apache 634 and getting to know it's foibles. Went away for the weekend with no EHU so needed to rely on the fridge on gas. Worked fine during the night but couldn't keep cool during the day. I've had this trouble with a previous much older fridge so is it simply a case that when on gas they can't keep cool when the weather is warm? Was only around 20 degrees (the weather) so not extreme and the fridge was facing West. Not sure when it was last serviced but hoping that this is all that's required or am I being too optimistic and just need to accept that on gas they are not up to coping with warm weather? Works amazing on EHU although also seemed poor when driving to site as arrived with the fridge temperature having increased.
Jan 28, 2008
10,255
18,640
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you need to get the fridge cold before it goes onto 12v when driving we plug in at home 24 hours before we travel
it seems these fridges have a sweetspot on the temperature selection usually around midway if you had it on full this could be the problem
7,953
27,203
Cheshire
C Class Elddis 175
8+ years
As a low cost but effective measure .Fit fans to the top of the fridge vents to draw cooler air in from outside( through the bottom vents) to cool the heat exchangers on the back of the fridge.
As a temporary measure when parked up you can take off your lower vent to allow more air through.
Lenny HB
55,841
162,878
On the coast in West Sussex
Carthago Compactline
On gas they work better than on mains.
You need to clean the chimney & replace the gas jet while you are at it also replace the thermal paste behind the fins inside the fridge.
1,718
1,692
Swift Suntor 590RL
My 18 year old 3 way fridge works better on gas than mains electric.
Last year we had it working fine on gas in 38c temps.
As Lenny says get it serviced.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
It had 24 hours plugged in at home so was lovely and cold before we set off, but was warm after an hour and a half driving to the site and then switching to gas. I did have it on the coldest setting so maybe should have set it lower, so will try this. Thank you.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Thank you for this advice. I can't even figure out how to remove the vents atm and don't want to break the clips, but sounds like a sensible idea.
4,202
6,887
Rochester
Auto-Trail Mohawk
17 fun filled years
Freeze a couple of large plastic milk cartons (with water) and stick them in when leaving home. Also the thermal paste may need replacing on the cooling fins which is an easy DIY job.
733
926
Swift Sundance 590RS
We have never pre-cooled the fridge before travel, we cannot hook up at home. The cold food will bring the fridge temperature down and its the last thing we load on the MH before we leave. Make sure the fridge is on 12V when travelling ensures the coolness is maintained until we reach site.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
I have a huge supply of ice packs so all good in that respect. Can you explain more about the thermal paste replacement or will a quick google lead me to how this is done? Also, would a professional service include that anyway?
564
2,023
Maspalomas, Spain
Giottiline Toscan 74
Mine is a Thetford 3 way, which automatically chooses the power source, and is brand new as it came with the van I just bought. So far, in temperatures of 30+ it is working very well on gas. We still have yet to plug the van into EHU so relying on gas and 12V when driving.
4,980
55,450
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
Just did mine. Gas burner fault (collapsed) now works perfectly again. £74 on EBay plus an hour of my time. 😎
Phil
7,382
8,785
Manchester
A class Hymer
Since the 80s
I'm not convinced that the thermal paste between the coolant pipes and the heatsink is relevant to this problem. The fridge works fine on 240V mains. It works less well on gas, and may work less well on 12V. The coolant pipe and heatsink are common to all three cooling methods, so if the thermal paste was failing it would be the same problem for all three heat sources.
I'd concentrate on getting the gas burner side of things working, including the solenoid, supply pipe, gas jet and flue exhaust flow.
