Dometic RML 9335 fridge power problems
Cotswolds, UK
Pilote 700GJ
Since 86
I’ve blown the winter dust off an am getting ready to go away but the fridge has no power on either 12v 240 v the power switch is dead
the 20amp fus is for 12v
the trip is live for 240v
without power there is no gas
help!
As well as the 20 amp 12v fuse (for the fridge 12v heating element) there should be another 12v supply for the control electronics on the fridge and this is normally around 2 amp . It may be near the 20 amp fridge fuse but could also be near the leisure battery positive terminal , on the EBL fuse board or in a separate fuse/relay board marked PLT02 (if fitted)
Hi I’ve checked the 2amp fuse and it ok it’s also the most difficult to get to in the world!!!
Thanks for your input
John
I can’t get any voltage readings on the heavy red and black 12v feed cable at muti plug in the lower fridge vent
I think you are probably right but you’ve got the multi meter probes in your hands nothing safe!!
