Hi everyone,
My fridge gets cold but so hot at back it’s burnt the van.
Any ideas ?
John
Any ideas ?
John
Hi,
Yes .it was flinting ok but wouldn’t light so I cleaned the jet etc and it lit 1st time and got cold then over night had terrible smell and outside burnt.
so you removed the fridge, cleaned the jet , put it back ,and in the morning van was burnt
That was my first thought excuse the pun but im a bit baffledIs there a spiral removable baffle fitted in the flue ?
Agree definately would be worth replacing the jet for a new oneHow did you clean the jet. The diameter of the hole in the jet is critical. If you used anything that enlarged that hole you would get a much bigger flame.
Sprayed it thru hole to clean then again just with air , that wouldn’t be enough residue .There is a large motorhome site on A64 north east of York, might hold spares
Good luck that looks scary
Edit- I don’t really understand what you did with the lighter fuel but wonder if the residual fuel ignited later causing the problem
Could it be soot rather than melting . May i suggest you try to clean it with Jiff /siff like vim if it cleans off then its not burned/melted and points to the jet and flame not burning correctSprayed it thru hole to clean then again just with air , that wouldn’t be enough residue .
Soot yes but burning and the smell was terrible , this alone was unable to live with, some mentioned ammonia? Also another mentioned turning fridge upside down for 24hrs . So suggestions that confuse the issue.This is how
mine is just for information purposes but I think grasshopper has solved your problem View attachment 934688
Can’t see flame whilst burning as it’s between my 2 outside vents as this was a desperate replacement for my original fridge.I suspect your efforts to clean the jet has ended up partially blocking it and the flame is burning yellow and badly
see if you can remove the metal cover and look at the flame
Turning the fridge upside down would be a desperate remidy for a fridge that doesnt get cold do not turn it upside downSoot yes but burning and the smell was terrible , this alone was unable to live with, some mentioned ammonia? Also another mentioned turning fridge upside down for 24hrs . So suggestions that confuse the issue.
Thats unfortunateCan’t see flame whilst burning as it’s between my 2 outside vents as this was a desperate replacement for my original fridge.
Thank you for all your help, I have now put my new jet in and so far it’s working, hopefully with all the stopping and starting it’s going to get on travels it stays that way.In this instance if it was possible and maybe not possibly as you are away,
1..I would get from toolstation or screwfix a mirror on an extendable stick take the fridge out take the cover of put it back and watch the flame with the mirror
OR depending if i had normal gas bottles buy a lenght of gas hose plus juberllee clips and a £8 regulator some block connecters a piece of wire and test the fridge standing next to the van
But as i say not always possible
Thank you for your help,How did you clean the jet. The diameter of the hole in the jet is critical. If you used anything that enlarged that hole you would get a much bigger flame.
