Dometic fridge
elspaniard47@gmail.
Fiat Ducato 2006
Hi I have a RM 7360 dometic 3 way fridge but can't get it to work on gas so I have taken the top panel off and on the far right is the flame sensor it has 2 thin wires but the red one is not connected and I can't seem to see were it should go thanks
I don't know about wires but sometimes fridge doesn't work on gas because of air in pipes. To overcome this light your gas hob on your cooker, then turn fridge on and off and hopefully it will clear the air locks.
Sorry can't help with wiring.
Thanks for your reply problem I'm having is because the wire isn't connected the flame indicator isn't working and I can't seem to find a pilot light
Some useful information for you. IMG_20230802_124651.jpgIMG_20230802_124651.jpg IMG_20230802_124559.jpg IMG_20230802_124550.jpg IMG_20230802_124453.jpg IMG_20230802_124444.jpg IMG_20230802_124444.jpg IMG_20230802_124331.jpg IMG_20230802_124305.jpg
w2f
elspaniard47@gmail.
Glad to hear you got the fridge working 👍
It's perhaps not a great idea to have your email address as your username on an open forum ?
If you want to change it and not sure how, Jim will help you.
You should have a unit on the back of your fridge like this.
The red connector should go into the hole I have marked with an arrow, you should find the black connector in the other hole.
