Dometic fridge problem
Selby, North Yorkshire
Rapido 8066DF
Morning all, i have a rmd 8505 fridge that will not switch on there is no power at all at the ridge controls, i have changed the 30a fuse in the main fuse box are there any other fuses elsewhere?. regards Bill
The control panel has a low current power feed separated from the 30a one which is just for the 12v element.
Different circuits and fuse in different set up unfortunately.
If you are handy with a multimeter you can test for 12v on the rear panel, behind the black cover. I’d test all the edge fittings on that circuit board as they are prone to oxidation and failure
