- Oct 12, 2020
- 149
- 30
- T337
- Newbie
Hi folks, I have a dometic fridge in a 2010 carado t337. It works fine on hook up. However on gas it is hit and miss and I never know if it's on or not until several hours afterwards when the fridge is cold or not. I can't really see a flame in the internal inspection window, nor outside when I remove the cover. When I turn the selector knob to gas, push the temperature knob in while its set to max and press the igniter switch, I get a whoosh of the primed gas igniting but it doesn't seem to keep burning despite me keeping the the temperature switch pushed in. I've taken the grill off the outside and blown compressed air in the ignition/burner area but it hasn't improved things. I've also tried lighting the gas from outside using a stove lighter and the same thing happens - the primed gas makes a whoosh noise, instantly burns off and then nothing. Any ideas? I've tried it both with only the fridge isolator switch on and with all the isolator switches on. The stove, oven, and heating all work fine.
