Running water sounds are considered a normal sound, failing to cool can be a few causes. May be a compressor or inlet valve problem, but check a few things, door closes properly all round, seals not split, drain hole not blocked and that there is no build up of debris on the rear pipework, a build up of dust can affect the heating section of the cooling system. I'm sure others on here will have further knowledge.Hi. I have a Dometic fridge freezer. Getting the sound of running water from it. Not cooling down No leaks. Any ideas on what could be wrong? Thanks
Thanks. I’ll check all these things this morning.Running water sounds are considered a normal sound, failing to cool can be a few causes. May be a compressor or inlet valve problem, but check a few things, door closes properly all round, seals not split, drain hole not blocked and that there is no build up of debris on the rear pipework, a build up of dust can affect the heating section of the cooling system. I'm sure others on here will have further knowledge.
Hi I have put it on Gas this morning so 8n give it some time. We are heading away this weekend so maybe it’ll sort itself outnot cooling on gas 12v or 240? or all three
