dometic 390 air awning attaching to canopy?
Hymer B578
Just starting out
Is it possible?
We only bought it a couple of months ago to go with the caravan. Cost £1200. I know it cant be used as a driveaway, but will it attach when we decide to stay a few days? Havent bought a MOHO yet.
Attach to what? It’s designed for a caravan shaped awning rail isn’t it?
Be easier to sell on via eBay (I’ve done this successfully quite a few times with unwanted items and you’d be surprised at the interest that these ‘nearly new’ items generate). Use the proceeds towards something that is designed to fit your M’Home.
It will fit as they are designed flat fitting not the older style all round a channel type.
How well it fits and if it reaches the ground is the question.
You don’t say what model so used the rallye sizes, they fit a height of 265cm rail.
The issue will be that the canopy is away from the side wall and the awning is designed to be flat with the wall. You can get foam block from what was Kampa to fill up these gaps even on a caravan. Why not list what type of van you looking at someone might offer the heights for you
My head is full of so many vans ive seen on autotrader. But one im drawn to is the auto-sleeper burford duo.
apart from the height issue that you need to check ( that is the height of the Kedar strip from the ground Versus the height of the awning rail on the motorhome) ; you also need to be aware of the habitation door height relative to the rear of the awning and if there is clearance to open the door.
