Dometic 3 Way fridge 70 litre capacity
Brixham Devon
Adria twin
Over 10 years
RM4231L (now replaced by RM5330 which looks identical except for the colour) Works well on gas/mains electricity/ 12VDC climate rating SN.
This fridge is for sale but must be fitted by a competent gas fitter but it includes the operating and installation manual and no reason why it cannot be installed in accordance with the manual and then connected and tested by the gas fitter. Gross capacity 70ltrs, net 60ltrs; frozen food compt 6.5 ltrs; weight 23kg. The door panel is light grained wood effect but can easily be replaced with any panel of max thickness 3.8mm
It has a step at the bottom back to accommodate the wheel arch but if you are not fitting it there it can be sat on a fabricated step. Prior to removal it worked perfectly on all functions and ignited within a few seconds with the knob depressed to over-ride the FFD Thoroughly cleaned inside and out and flue swept of soot so it cools quickly. Burner flame is blue as it should be.
Dimensions overall in mm external and including the cooling unit
Height 821 Built in dimensions 825
width 486 490
Depth 435 plus 39 for the door 450
Wheel arch step height 220
width 490
depth 225
It has an internal light and auto ignition if the flame goes out.
Reason for sale: I went for a larger Thetford compressor unit and fitted it above waist height for easy access.
Price the price for a RM5330 discounted by Leisure shop Direct is £790 so I think half of this is reasonable ie £395. I live in S Devon. Delivery is expensive due to the weight but I am going to the Malvern show and I can bring it with me for the buyer but I will want a substantial deposit first as I don't want to take it home again so please no time wasters.
Contact Jeremy on 07801 627805 or Jan on 07733 232416
