Doh (1 Viewer)
Apr 5, 2019
410
313
Lincolnshire
Low profile
I'm a newbie
Just been out to the Bailey MH, needed to check the cab battery soc.
Needs charging, so EHU goes on, pull the (leisure) battery fuse.
Cab battery now charging.
Check leisure battery SOC 84%, so want to discharge it a little (like to keep it between 60% - 80%), so put hab lights on and it's not discharging. ???
Penny drops after about 5 mins. of head scratching - BCA PDU is battery charger AND psu for for hab electrics.
The Artilleryman
Apr 5, 2019
410
313
Lincolnshire
Low profile
I'm a newbie
I believe that removing the fuse stops the leisure battery from being charged - confirmed by charge current into the battery dropping to 0.6A from 3.6A LiFePO4 BT app. - and hab battery reading 13.3A.
The Artilleryman
Apr 5, 2019
410
313
Lincolnshire
Low profile
I'm a newbie
Update - Isolates the battery from everything except solar controller, I think. Will need to do more investigation, when it gets warmer. Had gone out to put hab lights on to drop leisure battery to under 80% SOC only to find PDU controller dead, put fuse back in and all works.
Doing this sort of work this time of year is a pain, due to cold weather, much prefer spring/summer/early autumn, but then I'd be too busy with the miniature traction engine.
