LOL. Okay so only switch it on when on electric hook up. Thank youThe big red switch is your battery charger !!! I know this, not because I'm a man genius, although when younger my wife would often to refer to me as Oh God ! it's because my very high I.Q. has figured out the lettering underneath the switch that states CHARGER is in fact...........wait for it......... Yes! Its your battery charger. Switch on when on hook up ! Keep Safe.![]()
You have nailed it Obi Wan. That's not a taffy name by the way, pure Jedi, Like me!LOL. Okay so only switch it on when on electric hook up. Thank you![]()
Yes I could never get my mate to understand tha he was wasting his time leaving it plugged in at home if he didn0t turn that switch on.If only we had realised that if switch was on, it would have charged up the leisure battery again
No ...... never, ever, switch it Off.LOL. Okay so only switch it on when on electric hook up. Thank you
Reason my mate didn't like it on was that it is fan cooled & in the locker immediately behind drivers seat at high level. I must admit even I couldn't sleep with the fan running.You can leave it ON all the time. If there's no hookup there's no power going to the charger so it doesn't matter if its on or off. .
You only need turn it OFF if you DON'T want the battery to charge.
That suggestion, with all due to respect to The Big 1, about turning it off while not on hook up as it powers the battery etc is a nonsense electrically. The charger is essentially a transformer to drop the mains 230volts ac down to 12 volts and a rectifier to change the ac to dc non of which works the other way about unlike an inverter which steps the voltage up and dc to ac. While connected to the battery, the charger not on ac supply does not draw anything from the battery or solar panel. It don't work in reverse!I would suggest you turn it OFF if not on EHU and running an inverter wired directly in. Otherwise it will take power from the battery to er charge the battery. It doesn't work
And to the, probably AES, fridge.In that case, the inverter will send power to the charger.
