Does any know the best on board battery charger for dual batts
elddis aspire 255
Can anyone advise of me .I have 2x 100ah battery. Need a charger for the site hook up side 240>12 .and also I have 2 battery's is it better to take a +from one battery. The - from the other then run all the aux equipment from ghe + - feed through a bus bar or fuse unit .sorry if I've complicated the question .thanks
If that’s your van in the picture then it already has a charger to charge your leisure batteries….🤔
Thank you for reply .the charger in my van is for non lithium battery only does agm .or lead acid
The charger in your van will still charge lithium just not as efficiently as a charger with lithium setting. As a rule of thumb you need a 10 amp charger for every 100 amps of battery IE your 200 amps of batteries need a 20 amp charger or bigger 😉
Thank you for reply .I will look at a bigger more suited charger .
