Do 2020 and later Ducato locks still get spiked? (1 Viewer)
May 11, 2023
259
386
Globecar Summit 540
Following on from recent and other threads about the ease with which ducato driver doors can be opened by pushing a screwdriver or similar up under the lock, do funsters have any personal experience of whether post 2020 vans are still vulnerable or not? I understand that Fiat improved the design around 2019.
Aug 16, 2024
77
231
Hertfordshire, UK
dipping a toe
Its odd that major manufacturers don't put hook deadlocks on these as standard, likely cost between 25-50 per door if done during manufacture. Think it indicative of the distain they have for their customers...
Aug 16, 2024
77
231
Hertfordshire, UK
dipping a toe
As I'm in the market specifically for a PVC (plan A), I've been scanning the dealer websites. I must thave seen 100+ PVCs and not one of them seems to have any additional security, deadlocks, in your face alarms systems etc etc. So how common is it for addional security, how common are issues
I
May 11, 2023
259
386
Globecar Summit 540
From the lack of responses of any victims, it looks to me like spiking of 2020 onwards Ducatos cannot be much of an issue (y)
Or nobody is talking to me :cry:
hja
May 8, 2020
1,153
3,601
Lincolnshire
Globecar Summit Prim
Since 2019
We have a 2021 registered ducato. Simple answer, no idea. It has a factory fitted immobiliser and a dealer fitted tracker.
I
May 11, 2023
259
386
Globecar Summit 540
Thats what our 2023 one has too.
Badknee
7,482
433,103
notloB
Vantage Neo
Living the dream.
We must be bucking the trend then, alarm, tracker, immobiliser, disc lock on steering wheel, pedal lock, obd port cover, straps between front doors, 50 cal machine gun at side of bed. Anything else I forgot? :giggler:
I may or may not be joking about the 50 cal :whistle2:
Nov 21, 2021
70
46
Dorset, UK
Pilote V600G
Since 2020
I have 2022 Ducato and fitted a door plate.
It was obvious on fitting that it could have been easily spiked. The bar that operates the central locking was exposed and vulnerable.
stevewagner
2,014
4,584
Pevensey Bay
Carthago Compactline
Yonks
Our Fiat Hobby was broken into at Illkely Moor some years ago. They got in through the front passenger door which did not have an exterior key lock. The police called it bananaring. They said they grab the top and bottom of the door at the same time and distort it which releases the catch.
Nov 15, 2023
123
264
North London
Adria Compact SP Aut
Since 2008
I have an Fiat Adria Compact 2019 and my cab doors have been spiked a few times (going to get Proplates fitted as I have just noticed the area is getting rusty) but as I have lockable internal Heolocks on the cab doors and a cat 1 alarm - they have not succeeded in gaining entry as it only opens 2 mm before alarm starts blaring. Luckily on all occasions it has been outside in the road near my house, so I have watched them (behind curtains )being frustrated as to why they cannot open the door đź«°
Feb 12, 2018
856
5,699
South Yorkshire
Adria Coral 600SL
Since 2017
Perhaps externally-visible deadlocks would be a better deterrent in your situation. Internal Heolocks may be useful as an added means of security when sleeping onboard at night. However if the thief cannot see them they will not deter. Hopefully, with a visible additional deadlock the thief will seek an easier target.
Aug 16, 2024
77
231
Hertfordshire, UK
dipping a toe
Not sure proplates will stop attempts, maybe you should highlight existing holes, "try this hole, rather than make a new one, and fail like those before you"
Nov 15, 2023
123
264
North London
Since 2008
I have external Thule locks on my other doors & alarmed. I have seen the damaged caused by additional internal locks ie garrison by determined thief’s trying to jammy open the doors of trade vehicles in my area. Pro plates are to cover the external damaged caused by lock picking as I notice just recently an area of rust hence I wish it to be repaired and covered
Ridgeway
3,900
7,069
Lausanne
NiBi Arto 85E
Since 2012
however a vehicle comes from the factory as it’s a common design then people will always get around it, they’ll just figure it out. Adding anything additional to factory is always a deterrent
Shrimp
May 27, 2015
4,214
36,723
Bedfordshire, UK
Hymer B584
Long time
Our Hymer has extra locks on Hab & drivers doors, probably fitted by original owner, it also had an alarm with internal sensors.
It was still broken into thru the window!
