- Apr 18, 2021
- 206
- 753
- Sunlight Cliff 540
- Since 2008
I'm guessing you need a bulkhead at either end for that solution, which is something I don't have.I did something similar but then switched for a tension rod as they are really cheap. £10 for 5 typically.
Take one wire coat hanger, 2 pairs of pliers, et voila! Hangs off the 2 hooks provided in my van above the sink area. I dare say there are bespoke (i.e. expensive)View attachment 496030View attachment 496031View attachment 496032View attachment 496033View attachment 496034 versions out there, but this took 15 minutes to make.
No poor me at all, just posting in case it is of any use to anyone else - clearly not you, as you seem to have all manner of superior things in your obviously superior motorhome in your superior life!Cheap jibe I know but some MH builders do pay attention to details.
Some of us are supercilious; and others are just cilious [and less expensive]...No poor me at all, just posting in case it is of any use to anyone else - clearly not you, as you seem to have all manner of superior things in your obviously superior motorhome in your superior life!
I bet they provide a live-aboard mechanic as well to change any punctures?
I've been a member of this website for just over a few weeks, and every website seems to have one - just my luck to find the forum ars*hole so quickly!
No. Have you thought about spell checking?You're clearly the diy kitchen toll holder guru
Have you thought about branching out into other areas ?
Can I suggest that you read Rule 1 ... you appear to have been sailing close to the wind in 2021 with your comment and mentioning someone's spelling is a big no-no.No. Have you thought about spell checking?
I have a lovely 1960s/70s kitchen roll holder however across our 'kitchen' window I have a tension rod and on that I have a toilet roll which is ideal for the odd small spill, wiping down butter knives etc, rather than using a big sheet of kitchen roll.I did something similar but then switched for a tension rod as they are really cheap. £10 for 5 typically.
