Teasy2007
- Sep 26, 2007
- 2,086
- 1,159
- Carthago Malibu PVC
- Since 2005
This DiBlasi Electric tricycle is in excellent condition and has had very little use. It comes complete with the user manual and charger.
This is a twist and go model and has been used in Spain when we were in our Motorhome on holiday. It has an official Certificate of Conformity for use in the EU. The advantage of the twist and go are that you don't need to pedal and there is a smooth and easy start and ride. Once it is moving you can pedal easily and use the gears as in a normal bike.
As can be seen from photos it folds very neatly and will easily fit in a car boot or a Motorhome locker.
The DiBlasi Electric tricycle is the best you can buy and the only Electric tricycle which folds completely in seconds.
The price is £1250.00,it retails at £2580.00. The trike is being offered at less than half price and is in as new condition.
I prefer cash on collection in Mexborough.
If you put the following in U tube it shows how easily the DiBlasi folds and rides. Folding tricycle R32-R34 DI BLASI. More information can be found at Broken Link Removed
Product Specifications
Folding Tricycle R34
Specifications
Wheels. Stainless steel spokes & light alloy rims.
Tyres 20"
Seat. Height adjustable from 84 cm to 98 cm from the ground
Standard Equipment
Folding pedals
Bell
Front and tail lights powered by dynamo
Quick release seat levers
Rear carrier: Dimensions - 46 x 28.5 cm. Carrier's Max load : 10 kg
Dimensions - Open. Wheel base 95 cm. Track 70 cm
Dimensions - Folded. Length 64 cm. Width 28.5 cm. Height 62 cm
Weights. Tricycle weight: 30kg
Maximum rider weight capacity: 100kg
Electric Motor Engine: 24V - 250 W
Li-Ion battery pack: 24V - 8,5 Ah ; weight 4,2 kg
Range on flat road: more than 24 km
Specifications
Tyres 20"
Standard Equipment
Folding pedals
Bell
