DEKASYL MS-1 Adhesive sealant
DucatoEriba 2.8 2003
I am going to hopefully use this product to reseal a strip that lies above the drivers cab and joins the living quarters . ( fiat Ducato eriba.
Needless to say at this point I will have some movement when the MH is being used as it joins the cab and living quarter .
Can I please ask if anybody has used this product and if so is it durable enough to use on a moving joint such as this ?
I have screwed down this roof strip beforehand but a couple of places do not lie flush with the roof as it’s the old strip I have used .
Hope the above can be understood ?
David
Would industrial Velcro material be suitable? Some vans use this to hold panels in place and it allows for some body movement.
I will google this ..sounds different than what I’ve been looking for ?
David
Yep 👍
I’ve used it…. Works well for me
Yep 👍
The industrial velcro is very different from the usual loop and hook connection. Both surfaces are the same and require firm pressure to join together, they can be parted again but not without considerable effort. The adhesive is also best seen as a single use.
