Dash / knobs /switches/radio/anti freeze
CI Auto Roller
side switches seem to be lights..but there are some numbers on another dial..what do they do..also above that a switch with a light picture on it..would that be fog lights?and finally anti freeze does she need special sort...year 2000 fiat ducato ci 1.9TD..Sorry if all seems stupid questions but have no manual /owners handbook so am relying on all your help very heavily..thankyou...
is there a way to put a radio in? As never had one
knob on left is direction for air flow
middle one is hot/cold
right hand one is fan speed from 1 to 3 with no;4 being the' windscreen' emblem
& it tells you as it is pointing to "fan" emblem
yes the switch is fog lights
Oh & the slider below the knobs is either air in from outside or no air in from outside as in "recirculate"
anti freeze will be the older type & not one of the 'OAT' types .
Brilliant thankyou...for info..if only I could get owners manul
Thankyou..that's so helpful...am writing all this down..and will make a handbook /manual up of my own..so for future reference...have done this for the water tanks / hot water boiler and truma heater..although still can't seem to get hot water..so am doing something wrong...but all drained out and no water in the pipes..ready for winter...think I have so much to learn still..can get boiling water from shower and toilets on site so can still wash up...
The knob with numbers 1-3 is the headlight level ( on my 2001 based van this is a hydraulic system which tends to to fail)
The small button near ignition key puts the side lights on for parking if pressed as you remove the ignition key.
