Dark Comfortmatic Clutch fluid (9 Viewers)
Apr 18, 2022
7
Carthago
The clutch fluids dark even though it has been replaced recently.
1. What is the cause?
2. Will it eventually lead to master cylinder failure?
Many thanks
Jun 21, 2024
153
288
Harmony line 690g
"I believe it should be Dexron 111 Automatic Transmission
Fluid Red in Colour. đź‘Ť
Comfortmatic Gearbox Problems
There seems to be a lot of anxiety about the reliability of Comfortmatic gearb
misinformation floating around the web (and here)
The Comfortmatic system performs the operations your left foot or left hand (
vans) would usually perform in a manual van.
The gearbox and clutch in both the manual and Comfortmatic vehicles are ide
only occur in how the gear selector is operated and how the clutch master cyli
Gear Selection
The gear selector cam on a manual gearbox is operated by cables directly con
lever to provide the up/down and rotations required to select the 6+R different
Comfortmatic system the gear selector cam is operated by 2 actuators operate
solenoids in the Comfortmatic hydraulic module. 3 solenoids are required to r
of the 6+R manual cable operations. All of these gear selection operations are
gearbox so it doesn't know, or care what is actually changing gears inside the
The Comfortmatic hydraulic gear selector module is very reliable , the only fa
occasional cracked solenoid casings. These can be sourced and replaced but g
replace the whole unit just in case (and it's not their money).
Gear Selection system Durability
The fluid used in this gear selector module is Dexron III Automatic Transmis
red fluid in the rectangular reservoir on the top of the gearbox. The module ha
that captures any minor fluid weepage past seals and recirculates it back into
reused. The system has a very easy life by hydraulic standards and no parts w
should get used so it is effectively sealed for life and needs no maintenance. T
4th solenoid that feeds the clutch actuation system does not have a scavenge sy
Clutch Actuation
The clutch actuation in the Comfortmatic system is the same as the manual cl
cylinder is operated by hydraulics rather than the organic blob holding the ste
On a manual clutch when you press the pedal this pushes a pushrod in the clut
send fluid under pressure to the slave cylinder. With the Comfortmatic the 4th
selector module provides the hydraulic pressure to the Master/Slave unit to m
pedal pushrod operation."
I copied that off Google
56,350
166,448
Sounds like you could have a slave cylinder problem and getting cross contamination with the hydraulic fluid & actuator fluid.
I don't know if a dealer is able to aynalise the fluid otherwise may mean gearbox out to check the cylinder.
MisterB
6,827
15,687
Adria 670 SLT
Gear Selection
Clutch Actuation
I'm not so sure there are lots of misinformation floating around on here relating to comformatic gearboxes ..... Unless you're referring to your own post of course ...🍿
7,981
13,612
West Sussex
Malibu Van 640 LE K
Since 2003
Adams Morey told me that dark clutch actuation fluid means trouble ahead, having reassured me that mine was ok and clear when they drained it off. dunnah01 has over the years posted some helpful diagrams and pictures of the Comfortmatic Master/Slave cylinder. My simple understanding is that this unit has separate chambers and different hydraulic fluids are used for the clutch and gear selection parts of the unit. If the dark gear selection fluid gets into the lighter clutch fluid you have a serious problem. I also recall that some unorthodox methods of replacing the clutch activation fluid can cause problems, for example vacuum emptying can not only suck the lighter clutch fluid out but draw the gear fluid past the seals to pollute the clutch fluid.
What this amounts to is it is important that the Comfortmatic servicing is done by someone who really understands the system and knows how to drain and reset it properly.
M
Apr 18, 2022
7
Carthago
My comfomatiic fluid was very dark last year so I’m having it changed again on our way to the Santander boat to check it.
What year and milage was on your motorhome when you first had the fluid {dot 4} changed?
Has the new fluid got darker since it was fitted?
I believe it is recommended to be chamged every 2 years
3,347
103,565
Shropshire
Carthago chic e-line
A very risky procedure to carry out yourself unless you have the correct software program that puts the clutch through 15 cycles to ensure all the air is bled out and then adjusts the kiss point.
MisterB
6,827
15,687
Adria 670 SLT
To add further to the discussion, if the fluid is discoloured, will the repair be as expensive to have the seals replaced as soon as possible in comparison to suffering a complete failure? Is damage caused to such an extent that a new gearbox is required as opposed to the replacement of seals (though I know the labour costs and time involved even for an just replacement seals will not be 'cheap').
I am not advocating not having repairs done in a timely manner and I also recognise the inconvenience and additional costs in recovery from wherever the failure occurs.
We had our, thankfully clear fluid replaced 18 months ago and will be having it replaced again next year!
Kannon Fodda
2,891
8,802
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
The gearbox itself doesn't fail, it's the actuator systems that operate the clutch. The Comfortmatic system is effectively a manual gearbox and clutch that the servos and actuators are all robotically operated.
Usually when the clutch fluid is contaminated the slave cylinder in the clutch housing starts to leak risking contamination of the clutch plate, or the clutch simply fails to operate as the cylinder has gummed up.
But contamination shows the seals also have failed in the master servo form unit where both the clutch and gear change hydraulics are initiated. It's this form seal breakdown that is the cross contamination of the different clutch and hydraulic fluids. But as far as I know there is no service kit to renew those seals, hence the expensive replacement of the entire form.
Upvote 1
Nov 22, 2018
1,917
18,128
South East but not London
Rimor Europeo 87
Five years plus three tugging
I took the advice of the forum, and went to Adam Morey in Portsmouth.
Not cheap, but it is apparently essential to get every part of the drain/refil/bleed done.
A yardstick is that I phoned three motorhome workshops and all of them said they wouldn't touch a comfortmatic fluid change.
24,821
145,088
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I think that the OP is talking about the clutch fluid that is combined with the brake master cylinder as they have stated "Dot4" & it actuates the thrust bearing slave cylinder.This can become discoloured if the WHOLE brake system is not also changed .
The OP isn't talking about the comfortomatic system actuation fluid.
Ducato Self Build
Are you sure that the system was drained and flushed through completely and the garage didn't just suck out the reservoir and refill it?
4,693
10,446
South Lincolnshire
Rapido 7065+
Broken most bits now
If anybody has a scrap Master cylinder unit from a Comfortmatic I may be able to put together a repair kit. It's the part that sits with the main Comfortmatic unit above the gearbox. This is what sometimes fails and causes cross contamination and darkening of the clutch actuation fluid and eventual clutch CSC failure (like most modern manual gearboxes the CSC is the part buried inside the clutch bellhousing that needs the gearbox to be removed to change it)
3,347
103,565
Shropshire
The fluid is dark cos u didn’t get all the old stuff out if its combind with the brake fluid do it again and brakes at the same time and don’t panic
The comfortmatic clutch reservoir is separate from the brakes and only takes 50ml.
MisterB
6,827
15,687
Adria 670 SLT
Thanks Rob, but do you know if replacing that master servo kit when it shows signs of contamination (and the oils if course) would negate the need for a new clutch etc and therefore reduce cost and likelihood of total failure ( I know you've been through that scenario so you may know more than most)? I had my fluid changed 18 months ago (totally clear of contamination), based on your experience and am planning to have it replaced early next year, so hoping to avoid the issue completely.... So it's more if a general enquiry rather than an issue I am facing 🤞
Kannon Fodda
2,891
8,802
Usually once contamination has caused the master form unit to fail necessitating that being replaced there will have been damage to the slave cylinder too. Getting to that slave cylinder means you expose the clutch itself so for many it will be cost effective to redo the clutch plate whilst exposed.
In my case the clutch plate had failed as the incorrect operation of failing cylinders no doubt meant it wasn't being opened / closed fully. The notorious Fiat plastic thrust bearings things broke. So my clutch plate had to be changed but they avoided doing the dual mass flywheel part as at only 17,000 miles that should have had plenty of life left.
So really what needs to be done should depend on individual damage found and cost economics on future risk.
Prevention must be better than cure and I now ensure my Comfortmatic clutch Dot4 type fluid is being regularly changed to reduce that contamination risk.
M
Apr 18, 2022
7
Carthago
Its a 2015 Ducato with 36000km and the Dot 4 fluid was changed earlier this year for the first time
M
Apr 18, 2022
7
Carthago
Are seals available as "spare parts"
M
Apr 18, 2022
7
Carthago
The system was drained fully and flushed as part of the release bearing replacement. The next time 3 months later it was only the reservoir that was sucked out.
