Lenny HB
- Oct 18, 2007
- 58,098
- 179,336
- Carthago Compactline
Out of the frying pan into the fire with your, good luck it should be a nice solid van when you have finished.
When I replaced an internal wall on a caravan I used the West System expensive but worth it. When gluing the rear wall make sure you support the outside as well. The first part of the wall I did on the caravan had a slight curve in it because I only supported the inside. For the rest of the wall I used timber bracing on the outside against my garage wall.Thanks 68c for your detailed advice. Have had a look at boat building this morning and think the West system epoxy fits the bill nicely. Will go for the longer working time 105 + 206 mix with filler as needed. I will make a lap joint on the lengths and butt up against the widths and coat with epoxy during and after completion.
My Bessie still has the original ply covered with the vinyl sheet acrosss the rest of the flooring, would it be worth removing all of this and epoxying the whole floor before painting? I really doubt that the ply is marine grade when built in 2006.
Thoughts?
