The Curly's
- Oct 20, 2019
- 32
- 16
- Hi Top
- I'm a newbie
Not with normal Polyester resin found in DIY repair kits though as the resin will melt the Polystyrene insulation, epoxy and glass fibre would be OK for a localised repair and then get a new graphic made with a white background and no need for paint even.dead easy fibre glass repair![]()
It’s definitely repairable, but I would recommend a professional approach rather than a diy job. Most diy repairs are still visible afterwards, either imperfect repair or the wrong colour or they deteriorate in time.Thank you for your reply crazy legs. I will contact them this morning. Do you think it would need a new panel or is it possible to repair the damaged area?
As I said you will get a much better job done by a boat repair guy. Body shops tend to bodge GRP repairs, they fill and spray rather than using gel coat for the finish.Thank you all for your help and advice. I think I will try to take it to the the body repair shop and get it repaired rather than go through my insurance company.![]()
Take the advice above and go to a marina, they specialise in waterproof repairs, though their mistakes aren't generally visible from the bankThank you all for your help and advice. I think I will try to take it to the the body repair shop and get it repaired rather than go through my insurance company.![]()
