- Sep 25, 2023
- 781
- 975
- Swift Sundance 590RS
I currently have a cycle rack on our new to us MH. I think its a Thule/Omnistor given the colour of the trim. The rack plastics are badly weathered so was looking at options.
I can cut off and replace the tightening bolts relatively easily and can replace the knobs with lockable ones from eBay if needed. The other clamps are also pretty worn and cracked and not sure they will be easy to replace.
The MH is 52 plate Swift. The Cycle Rack mounts are 600mm centres and 500mm depth. I found a Fiamma CL might fit if I can adapt the lower mounting. I don't particularly want to change the mounts as they are behind the end kitchen.
The top mount is a hook but cast rather than bent tubing as per the original.
Top Mount
Lower Mount which is narrower than the replacement.
I believe the Fiamma mounts are like this. Anyone any idea if they would fit over the same hook bar top mounts.
The lower rail could be bolted on the the old narrow rail, I hope.
Top Mount
