I am thinking about having a diesel heater fitted to our coach built motorhome does anyone know the likely cost of a quality heater and installation fed from main fuel tank, any advice appreciated thanks.
I fitted my fuel take off on the breather pipe elbow ( pulled out the elbow and drilled and fitted the fuel pipe , then fitted it back without disturbing the sender etc.)but replaced the fuel pipe for a better one . My logic there was that the elbow is easily replaced rather than trying to plug a hole in the top of the tank.In a ducato the fuel tank top is between the seats under a cover, you need to remove the sender an fit the pick up fuel pipe, (you do need special tools for this about £10) If it is a diy job i will post them to you. the fitting of the heater is a matter of planning as you only get one chance to position it correctly so plan and measure before starting. I fitted a Chinese one to my van about five years ago and it has always worked well ( i did buy A spare heater kit just in case but it now gathers dust in my shed)
convience of getting diesel in volumeIf you already have gas heating and have a refillable system (Gaslow), is there any advantage in fitting a diesel heater?
I understand it would cost less to run but is there a big difference considering gas is cheaper than diesel (per L)?
There are 10kWh of heat in 1 litre of diesel and 7kWh of heat in 1 litre of LPG (propane) so the price per litre is not a straight comparison. At £1.50 per litre diesel costs 15p/kWh and at £0.90 per litre LPG is 12.9 p/kWh. LPG wins using my local Morrisons price. However if Morrisons stop selling LPG, which is a sad possibility, the next 2 nearest suppliers are now charging £1.10 and £1.20 per litre by which point diesel is cheaper. The break even point with diesel at £1.50/l is LPG at £1.05/l.If you already have gas heating and have a refillable system (Gaslow), is there any advantage in fitting a diesel heater?
£2000 for a quality pro install or £90 for a DIY versionI am thinking about having a diesel heater fitted to our coach built motorhome does anyone know the likely cost of a quality heater and installation fed from main fuel tank, any advice appreciated thanks.
Can I ask about the diesel combi 6E? When you say new van have you opted have it factory fitted, or will this be work after you get the van? Thanks.There are 10kWh of heat in 1 litre of diesel and 7kWh of heat in 1 litre of LPG (propane) so the price per litre is not a straight comparison. At £1.50 per litre diesel costs 15p/kWh and at £0.90 per litre LPG is 12.9 p/kWh. LPG wins using my local Morrisons price. However if Morrisons stop selling LPG, which is a sad possibility, the next 2 nearest suppliers are now charging £1.10 and £1.20 per litre by which point diesel is cheaper. The break even point with diesel at £1.50/l is LPG at £1.05/l.
I have opted for a Truma Diesel Combi 6E in my new van, not because of fuel cost but because of:
i) Ease of purchase, 1 fill up does both heating and road fuel, no need for a separate stop.
ii) Availability of fuel, any forecourt sells diesel.
iii) Weight, 1 x 5kg gas bottle to run a 2 burner hob max weight 8.4kg v 2 x 11kg Alugas bottles to run gas heating max weight 36kg.
iiii) Space, I intend to repurpose most of the gas cylinder locker as a tool cupboard.
Malibu Van factory fitted option.Can I ask about the diesel combi 6E? When you say new van have you opted have it factory fitted, or will this be work after you get the van? Thanks.
It's just more convenient.Can I ask about the diesel combi 6E? When you say new van have you opted have it factory fitted, or will this be work after you get the van? Thanks.
Thanks. Wish it was with our Adria Twin SLB. Seems to be with the SGX, but we had no optionMalibu Van factory fitted option.
That is a shame, the latest Combi D has the same footprint as the gas version so there shouldn’t be any difficulty offering it as an option. BillandHelen had their gas Combi changed for a diesel one.Thanks. Wish it was with our Adria Twin SLB. Seems to be with the SGX, but we had no option
I have just thought of another reason:I have opted for a Truma Diesel Combi 6E in my new van, not because of fuel cost but because of:
Yes, we found it strange that Adria could/would not swap the gas for diesel version. Maybe it's a production line issue? But then again, why not just put diesel heating in all vans as I think Chausson and Challenger are/were doing. I'll probably go down the route of BillandHelen and swap gas for diesel. We have a local motor home workshop that can do it.That is a shame, the latest Combi D has the same footprint as the gas version so there shouldn’t be any difficulty offering it as an option. BillandHelen had their gas Combi changed for a diesel one.
v) Refillable cylinders have to be replaced every 10 years the diesel tank should last longer.
"one of us doesn't do cold and am a believer in that famous saying that all married men know (or should)."Wow Thank-you that's great info, we do have gasflow but find lpg hard to find at times and the morrison forecourt selloff has made me think another form of heating will come in handy as we intend to do more rallies ths's etc this year, ps, one of us doesn't do cold and am a believer in that famous saying that all married men know (or should).
