No the material is so thin it would not hold a new plug assembly.Would it be possible to use the increased size hole you now have in your basin, and fit a bigger waste?
Good thinking, I'll have a look.Would it be possible to use the increased size hole you now have in your basin, and fit a bigger waste?
The sink has fractured and the drain has fallen through.Has it damaged the sink or just come loose and fallen through?
what size hole are you now left with?Good thinking, I'll have a look.
The hole is 62 dia, do they do drains that big?what size hole are you now left with?
Sink is ok but i have a 60 dia where the plug should be.The sink has fractured and the drain has fallen through.
Thanks for the info looking in to it.![]()
McAlpine Centre Pin Basin Waste Polished Stainless Steel 60mm - Screwfix
Order online at Screwfix.com. Centre pin dry fixing connection has the advantage of quick, simple and neat installation. Polished stainless steel flange eliminates the problem of chrome plating deterioration. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
