Was only thinking of using it when hooked up. Would this make a difference Hobo?I think, a low wattage micro is okay but I think a combi might trip the EHU, it all depends on the start-up watts?
Should be OK bear in mind the start up power can be up to double the microwave rating ones like the better Panasonics with inverter technology have a lot lower start up power. Most of the small ones should be OK on a 6 amp outlet, definitely Ok on 10 amps.Was only thinking of using it when hooked up. Would this make a difference Hobo?
