Control panel (1 Viewer)
Tablesawjock
5
Gizmomax100@
Hi guys I have a elldis autoquest 130 2007 no power to amp meter or water guage no water pump either any pointers very new to this any help would be much appreciated
Apr 1, 2024
238
353
Bolton
Hobby T500 LHD
Spring 2024
Unless you have lighting and other things working I would suggest that you have a dead leisure battery.
Two on Tour
10,798
55,696
Elddis Autoquest 175
Since 2010
Are the other 12v circuits still working, i.e hab lighting, heater blower etc ?
Have you checked our leisure battery voltage with a multi meter at the battery ?
T
Tablesawjock
5
Gizmomax100@
All lighting is fine ignition on hob working the only things are guages and water pump pump in toilet works but no water from main tank as main pump no power everything seems to work apart from what I mentioned to do with main control panel
T
Tablesawjock
5
Gizmomax100@
All conections are secure at back of panel don't know what colour are what to see if it's getting power it goes into a large multi plug behind panel in wardrobe apparently colour coding is different from van to van even elldis can't help 😀
T
Tablesawjock
5
Gizmomax100@
Main switch at door is on lights and other 12 volt seem OK just the guages and water pump not working all fuses are OK 12.8 volts at leisure battery when mains cable plugged in it goes up to 13.8
Don't know colour coding to see if power is going up to switch just purchased it don't know much about them so on a steep learning curve
303
3,146
Fareham
C class
Since 2017
Is there a fuse behind the gauge panel. Or one of the switche connectors come loose. Do you have 12v to the back of the gauge/switch panel.
