The step should not work with the engine running, ours doesn't albeit a Swift Sundance.Put your step out whilst engine running. Do you get another buzzer, or no change?
So you couldn’t put the step out then start engine?The step should not work with the engine running, ours doesn't albeit a Swift Sundance.
Yes you can. So engine off and extend the step, but as soon as you start the engine the buzzer sounds immediately and the step retracts. Once retracted if the engine is still running you cannot extend the step.So you couldn’t put the step out then start engine?
