We are finally away on our first proper long trip yayy!! However I need to work on the road a bit so we had a motorhome WiFi installed. The first sim we used lebara didn't work so we switched to Smarty which worked fine on a couple of days visit to the New Forest. However we have arrived in Wales and although it says full signal and my laptop connected initially, it quicklyropped off and now say connection issues. The TV is the same and our phones have intermittent connected to it, however they work fine on data roaming.
Is this just a common problem I should expect or could there be an issue with a simple fix to try? I can't try our phone sims in router as they are lebara which don't work. Smarty's network coverage says it should be fine here...we are in the Gower peninsula Wales and its pouring with rain, maybe that's the issue?!
Thanks for you any help you can give me
Lisa
Lisa
