HI
I am looking at increasing my Solar from 100W to 200w by adding a second 100w panel. However I dont have a lot of cable to play with between the existing panel and the waterproof housing to try and connect in some MC4 connectors and then use a y Splitter to connect the two panels. There is maybe a couple of inches of cable I can free up between the MPPT controler and the panel but I am not sure it will be enough not to compromise any connector I put in if a do cut it. Any ideas?
Plan B may be to remove the 100w panel and fit a single 200w panel.
Thanks Howard
Thanks Howard
