The neatest solution is to fit a relay which disconnects the sockets from the mains and connects to the inverter output. This is what I did but it isn't a simple DIY job and you need to be confident working with potentially lethal voltages and ensure you don't create a fire hazard. Sourcing the correct relay was a bit of a chore too. There's a link in my signature below on how I fitted mine. The relay looks like this:Can anyone give me some advice as to if its possible to connect an inverter to an existing 13amp socket and if so how To do it,
Thanks for any advice given
That's a great solution Paul. Could you share where you sourced the sockets?I went the route of wiring in additional sockets powered by the inverter mounted next to the original EHU 240 sockets. I used sockets with flaps that denote that they are inverter sockets.
Depends if you want the sockets to automatically switch between MHU and Inverter power. If not, then the above advice is sound enough.
If you do want them to switch over automatically (which is a project I'm about to start), then you need a mains triggered Connector Relay. Something like this. Sockets are connected to all four outputs (just join Live to Live terminals, and Neutral to Neutral), Inverter power is connected to the NC feeds, MHU is connected to both NO feeds, and the relay trigger.
As soon as MHU is plugged in, it triggers the relay and the feed is changed from the inverter to MHU. Simples!
Good idea. We’re the other way around, though; we are rarely on EHU. I like the idea of also being able to choose which to use.Thats how I did ours, but I wired it the other way round so the inverter triggered the relay. That way the relay isn't being engergised for days and getting warm while on EHU and only on for short bursts instead. Plus if on a low amp EHU we can turn the inverter on and it still switches the sockets. Seemed a more useful setup,
Great feedback thanks PaulI bought and fitted ours a couple of years ago so suppliers and prices have changed.
They are CBE C-Line and having had a quick scan of the internet the prices vary widely for the same item. I'll list the parts but would advise you to hunt the best prices.
C-Line 230v Socket - The Caravan Accessory Store
The C-Line 230v Socket is for use with the C-Line modular socket system and compatible with the CBE components. The 230v 3-pin socket is compatiblebigwhitebox.co.uk
C-Line Circular Back Box - The Caravan Accessory Store
The C-Line circular back box is for use with the C-Line modular socket system and compatible with the CBE components. The back box fits recessedbigwhitebox.co.uk
http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=233590611400
which is the correct and safe way to do itI fitted a 30 amp changeover relay which swaps all the sockets over but the fridge and charger only feed from the mains input.
Default is all sockets connected to inverter plug into EHU and sockets swap to the incoming mains. My relay is mains powered to cut down on battery drain as we rarely use EHU.
I went same route using separate sockets, i realy like the use of deliberately different sockets. Currently my use of ehu and inverter is so small i would direct you to some other method to alternate use, relay if you are resistive to manual switching.I went the route of wiring in additional sockets powered by the inverter mounted next to the original EHU 240 sockets. I used sockets with flaps that denote that they are inverter sockets.
